1
This discussion topic has been answered Discussion topic: WiFi temporarily full
This message was authored by: Steve-Alison
Can't connect to my WiFi router after a reboot
Re: WiFi temporarily full
@Steve-Alison unless you have over 200 devices the Sky hub's wifi wont be full. A simple reboot should not change the wifi password but if you held thecreset pin in too long the hub will have reset to its factory settings w hich resets the wifi password to the default onnthe label.
