2
This discussion topic has been answered Discussion topic: Change Sky Max Hub Wifi details via Web browser
This message was authored by: Neskutz
Hello,
we just got a new WIFI in our household, the new Sky Max router, and want to change the WIFI name & password.  i see the posts/videos to change the Wi-Fi details via MySky App
But can we do it also via the web browser?   I have logged in the hub and navigated to the WIFI tab, I see the details are grey out, there is also a 'Disable' button, so i wonder if could disable the WIFI, change the details, and then re-enable it.
will that work or will let me in limbo with the WIFI disabled?
thank you
This message was authored by: JimM1 Answer
Re: Change Sky Max Hub Wifi details via Web browser
@Neskutz With the sky Max hub, you can ONLY use the app to make changes. The web interface does nothing!
@Neskutz the full hub's settings to control the WiiFi are only in the My Sky app so you cannot use a web browser. Sky had said they would add them to the My Sky website but as yet you seem to only be able to manage the WiFi security setting.
The hub's web interface is purposely disabled and should not be used apart from switching UPnP.
