Discussion topic: Internet problems
Message posted on 23 Aug 2025 06:32 AM
Internet problems
Anyone else having internet problems in Woodbridge area??
Message posted on 23 Aug 2025 08:05 AM - last edited: 23 Aug 2025 08:07 AM
Re: Internet problems
There were issues yesterday afternoon/evening in Birmingham, and parts of Worcestershire and Shropshire if Woodbridge is near there.
edit: I now see you're in Suffolk.
Otherwise if you haven’t done it yet, use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 23 Aug 2025 08:23 AM
Thanks for your help.
