Discussion topic: WiFi strength
Message posted on 27 Jul 2025 12:32 AM
WiFi strength
Done a WiFi test but music videos are buffering and it is not at the level the WiFi test says it is
Message posted on 27 Jul 2025 07:37 AM
Re: WiFi strength
@Catherine225 to stream video or audioyou need both sufficent bandwidthbut as important is stability of the signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
