Discussion topic: WiFi speed 5mbps
Message posted on 24 Dec 2024 10:01 AM
WiFi speed 5mbps
My WiFi speed keeps dropping down to between 4 and 5mbps recently. I work from home and it is so unreliable. Today it's atrocious
Message posted on 24 Dec 2024 10:45 AM
Re: WiFi speed 5mbps
@Crunchie1978 check the speed to the hub by running the Service Checker in the My Sky app which if you click on the Broadband link will show the recent speed history and the guaranteed speed for your line. If the speed to the hub is below the guarantee then the app should offer further help.
If however that is all as it should be the problem is the WiFi signal in your home which isnt guaranteed by Sky. You can buy an add-on from Sky which does get you a wifi guarantee see https://www.sky.com/help/articles/sky-wifi-max
