Discussion topic: Wifi using members
Message posted on 24 Dec 2024 09:43 AM
Wifi using members
can i see how many login members logined on to my sky wifi account and can I see the history of login to check unknown logins
Message posted on 24 Dec 2024 10:03 AM
Re: Wifi using members
No, there isn't any login to WiFi. The network name and WiFi key is an encryption thing.
Message posted on 24 Dec 2024 10:41 AM
@Gokulll you can see devices connected to your Sky hub in the hub's web interface but the lists can be confusing as the name listed may not mean much or simply say unknown. Do you suspect somebody is using your wifi who shouldn't be? If so change the WiFi password see https://www.sky.com/help/articles/find-and-change-your-wireless-password
Message posted on 24 Dec 2024 10:53 AM
@Gokulll wrote:can i see how many login members logined on to my sky wifi account and can I see the history of login to check unknown logins
If you go into your router statistics Here and go to connected devices you will see offline devices ie, devices that previously connected to your hub and can check which ones may not be yours.
Sky Q 1TB UHD
LG TV
Sky Mobile
