Discussion topic: WiFi slow
This message was authored by: IainDavid
WiFi slow
WiFi is so slow and everything is lagging. Very poor atm and seems to be getting worse not better.
Re: WiFi slow
@IainDavid  black or white router from Sky?
Avatar for IainDavid
Re: WiFi slow
Black router.
Thank you
Re: WiFi slow
@IainDavid Could you please post your router stats following the link below.
Re: WiFi slow
Sky Hub Status
This page shows the current settings for your Sky Hub. We have preconfigured your Sky Hub with the optimum settings. This is a read only summary page. If you wish to change settings use the menus at the top of this page.
  • Select Show Statistics to see your Sky Hub performance statistics such as the number of packets sent and number of packets received for each port.
  • Select Connection Status to see information about your current connection.
System Detailshelp
ManufacturerSky
ModelSR203
Firmware Version7.03.0704.R
DSL Firmware VersionA2pvfbH043p1.d26u
Modemhelp
Modem StatusConnected
Traffic Type:PTM
Line Rate - Upstream (Kbps):9521
Line Rate - Downstream (Kbps):39999
IPv6 Loopback Address[information removed]
Broadband Porthelp
MAC Address[information removed]
IPv4 Address[information removed]
Network TypeMER
IPv4 Subnet Mask255.255.252.0
Gateway IPv4 Address[information removed]
IPv4 Domain Name Server[information removed]
Gateway IPv6 Addressfe80::22
IPv6 Domain Name Server
IPv6 Global Address[information removed]
IPv6 Link Local Address[information removed]
IPv6 Delegated Prefix[information removed]
LAN Porthelp
IPv4 Address192.168.0.1
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULA[information removed]
DHCPv6On
WiFi Porthelp
Name (SSID) [information removed]
Region Europe
Current Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi AP Enabled
Broadcast Name Yes
Connection Status Show Statistics
Moderator note: personally identifiable information removed
Re: WiFi slow
@IainDavid  You need to go to the bottom of the information you posted and click on show statisics to get the information we need.
Re: WiFi slow
Router Statistics
System Up Time: 2475:57:40
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 1135420355 2288785277 0 327755 1376691 129:25:15 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up   :55:52 WLAN (5 GHz) Up 2080654806 1054334962 0 0 0 2475:55:52
Broadband Link Downstream Upstream Connection Speed 39999 kbps 9521 kbps Line Attenuation D1(15.3 dB) , D2(38.8 dB) , D3(59.1 dB) U0(4.9 dB) , U1(29.1 dB) , U2(44.4 dB) Noise Margin 23.0 dB 6.3 dB
Re: WiFi slow
How do you post this information?
Is this what you need?
Re: WiFi slow
Re: WiFi slow
@IainDavid  That router has been up for sometime and needs a re-start. But can see that your connection should be more than you are getting just now. Could you run the directions below and see if it gives you the ability to book an engineer. More the latter of the directions if it does not let you do this come back let us know.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
This message was authored by: Metis
Re: WiFi slow
Hello @IainDavid
Just going slightly off topic, just curious if your able to get Full Fibre services at your property.
Can you go to this broadband checker and post the results, minus your address details.
Re: WiFi slow
All green from the test. No need to book engineer but worrying how slow it's become
Re: WiFi slow
@IainDavid  Looking at the information on your router stats you should be on more than you are 23.0db is not correct and it should be around 6 so this is showing there is a fault in the line. If you would like help with this I can alert Sky for you?
Re: WiFi slow
Yes please, any help to improve service and if there is a fault shouldn't they identity this and correct
Thank you
Iain David
Re: WiFi slow
@IainDavid I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147/
