Discussion topic: WiFi signal
This message was authored by: Fran-s
WiFi signal
None of our phones are connecting to the WiFi since l have had sky installed.
Re: WiFi signal
@Fran-s
What happens when you try to connect them to your Sky Wi-Fi connection ?
This message was authored by: Jynxy
Re: WiFi signal
Have you setup your phones to connect to the new router ? these details will be different to your old router.
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
