Discussion topic: Wi Fi dropped off
This message was authored by: Kenh2
Message posted on 19 Apr 2025 04:33 PM
Wi Fi dropped off
I activated my wi fi today, following a replacement hub, it was running perfectly, but has since stopped working. Of the four lights on the front, I have 2 green and 2 amber, in the following order, GAGA. Anyone have any suggestions for this?
This message was authored by: Jynxy
Message posted on 19 Apr 2025 05:07 PM
Re: Wi Fi dropped off
What router do you have ? have you tried turning the wifi off and back on again, you could also try to reboot to see if that helps before trying anything further.
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
