Discussion topic: VERY slow speed on SKY ULTRAFAST MAX (ROI)
This message was authored by: BartM8
Message posted on 19 Apr 2025 04:37 PM
MY download speed is only 8mbps and upload not much better at around 12mbps.. shocking speeds
This message was authored by: Jynxy
Find out more
Message posted on 19 Apr 2025 05:04 PM
Re: VERY slow speed on SKY ULTRAFAST MAX (ROI)
Hi,
Is this via wireless or wired connection?
what does it say here under broadband, this will report the speed to your router and rule out a connection issue.
https://www.sky.com/servicechecker/
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
