Discussion topic: WiFi router red light broadband not working
Message posted on 26 Jun 2025 09:50 PM
My sky broadband router had a solid red light and no devices are able to connect to the internet. Ran system checks multiple times only for them to come back and say there isn't an issue which clearly isn't correct . Used the sky bot but keeps repeating the same solutions of running a system check and then timing out. Very frustrating
Message posted on 26 Jun 2025 09:52 PM
Re: WiFi router red light broadband not working
If the red light it still present after a reboot then did you run the broadband line test as per this:
If this is of no help give Sky a call to report it to them.
Message posted on 27 Jun 2025 07:35 AM
Thanks - yes, finally after a couple of hours the sky testing page showed their was an error. Despite going through all the various steps multiple times, no joy.
I've logged an escalation to sky last night but given it can be up to 72 hours for a response, I'm not holding out much hope. This morning the red solid light is still on the router.
I've finally found the phone number for customer service as well (which is very hidden on the site!) so will have to try that as well
