Discussion topic: WiFi problems
This message was authored by: Sean127
WiFi problems
Suffering with intermittent WiFi so cannot watch iPlayer without it stopping
Re: WiFi problems
@Sean127 if other devices are working normally it sounds like there is notvsufficent wifi signal reaching the devicecyou are using to watch iPlayer. In many homes you need morecequipment than a basic Skybhub tobstream video especially if the TV is in.a distant room. You can buy Sky's add-on package called WiFi Max which can supply up,to 3 extenders or buy and use your own Wifi equipment
