Discussion topic: WiFi password
This message was authored by: Joe217
WiFi password
Hi, I've installed my new router but after entering my password it says it's wrong. I'm aware it's case sensitive. I've tried resetting the router but still no luck.
I connected my phone using the QR code and that works fine.
please help
Re: WiFi password
@Joe217
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this.
Avatar for Joe217
Level 0 icon
Re: WiFi password
Sorted now, thanks. That was the problem 🤦
