Discussion topic: B67 area, wifi keeps dropping out
This message was authored by: SC-71
Most if Sunday 22nd and still today, wifi drops out and disconnects, then quickly connects again. May seem a small issue but when online in meetings, disconnects the call, online in games, disconnects from group. Latency went through the roof at some points.this is all devices. I can see down detector is logging more and more issues over the last 24 hours. Having to use mobile hotpot for work laptop at the moment.
Re: B67 area, wifi keeps dropping out
@SC-71
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
