Discussion topic: WiFi only working in front room
This message was authored by: LawrenceTurlej
Message posted on 10 Jun 2026 03:21 PM
The WiFi doesnt have enough signal to connect to the bedroom which is next to the front room in my flat. Pretty dreadful WiFi coverage
Find out more
Message posted on 10 Jun 2026 04:48 PM
Re: WiFi only working in front room
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
