Discussion topic: POOR SIGNAL
This message was authored by: JIMSAPHIN
POOR SIGNAL
After switching over to SKY full fibre the connection close to the router is excellant but was weak on the other side of my property. i purchased twi TP boosters and added them in the furthest rooms but the connection is still bad. I have to keep walking back to the router to get conected. Please advise me as I'm not a happy customer.
Thank you. Jim. East Sussex
Re: POOR SIGNAL
@JIMSAPHIN
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Re: POOR SIGNAL
Perhaps note that boosters cannot work when actually located in areas which have poor WiFi: they are intended to be mid-point devices to rebroadcast signal into those areas from closer to the router.
