Discussion topic: WiFi not working
This message was authored by: Mollie02
Message posted on 14 Apr 2026 01:29 PM
WiFi not working
Hello
I have just had an electrician checking the work in my home and since the electric has been switched back on the wifi is not working and the box will not light up.
Find out more
Message posted on 14 Apr 2026 05:58 PM
Re: WiFi not working
@Mollie02 check thst it isnt a dodgy socket or circuit breaker left off but if thecsocket is OK it sounds like the hub has failed so call Sky to get it replaced.
