Discussion topic: Poor WiFi Signal
This message was authored by: AJN7
Poor WiFi Signal
Hi There,
we recently undertook the free upgrade to fibre option and since then have been experiencing poor WiFi coverage round the house - to the point our work MSTeams calls are being effected.
can you please rectify asap?
Re: Poor WiFi Signal
@AJN7
This is a customer helps customer forum so you are not actually talking to Sky.
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
