Discussion topic: WiFi not working
This message was authored by: CheekyB1
WiFi not working
Hi
i ran a diagnostic check today as sky says my WiFi is t connected. It showed that the hub was connected but not the WiFi. I've rebooted everything.
please assist in how to overcome this.
Re: WiFi not working
@CheekyB1
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
