3
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Katieg85
WiFi not working
WiFi is not working
Re: WiFi not working
@Katieg85
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@Katieg85
This message was authored by: SophieERC
I'm facing the same issue but when I run the checks it says nothing is wrong.
I cannot seem to speak with a human, only the AI bot
@SophieERC
Did you read paragraph 2 above?
