Discussion topic: no broadband connection
This message was authored by: Caroline174
having an issue with my broadband. Thanks
Re: no broadband connection
@Caroline174
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
