Discussion topic: WiFi not working
Message posted on 12 Nov 2025 02:49 PM
WiFi not working
My wifi does not seem to be working, I now have no tv and my autistic son has no access to his devices which is causing huge problems
Message posted on 12 Nov 2025 03:18 PM
Re: WiFi not working
@KEW0812
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
