This discussion topic has been answered Discussion topic: WiFi not working
Message posted on 06 Nov 2025 11:21 AM
My WiFi isn't working! I have a green light for power, no lights in for internet and WiFi and a red light on voice.
Message posted on 06 Nov 2025 11:22 AM
@ELmomda
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@ELmomda
