4
This discussion topic has been answered Discussion topic: WiFi not working
This message was authored by: Kiki6
WiFi not working
I have no WiFi, did a check online and sky is telling me there's no problems although the sky box and sky glass cannot connect?
Re: WiFi not working
@Kiki6
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@Kiki6
This message was authored by: SootyBlue
Same issue here this morning.
@SootyBlue
Same advice applies.
Solved! There had been a power outage which had lasted long enough for the sky router  to factory reset itself. When power was restored the broadband reconnects automatically but WiFi had gone back to its default (original) pass key. All the devices were set to our new password so had to change router settings to bring it back into line with everything else. Sky Q and booster boxes were also a total pain to reset and link up again, but that's another story.
