Discussion topic: Connection
This message was authored by: Amy+Marshall+x
Connection
Please can my WiFi connection be looked into. We upgraded to superfast as I am now working from home full time. However the last 2 days my computer has struggled with connection and cuts out
Re: Connection
@Amy+Marshall+x
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
