Discussion topic: WiFi not working
Message posted on 30 Oct 2025 05:09 PM
WiFi not working
My router is in green but the internet keeps dropping out. Tests say it's running fine but it's not. Now the middle light is orange. We have reset the router and no difference. This has been going on for 3 days.
Message posted on 30 Oct 2025 05:51 PM
Re: WiFi not working
@Elisha1262
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
