Discussion topic: Sky Broadband not working
This message was authored by: Annoyed67
Hi Since my fibre broadband was installed over a month ago the internet keeps dropping out or not connecting. You go on the app and check and it says everything is fine but it's not. I'm sick and tired of paying for a service that's not working and can't get through to a actual person to talk to. To get this fixed or I will cancel my sky
Re: Sky Broadband not working
@Annoyed67
No point in threatening to leave here. You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
