Discussion topic: No middle green light
This message was authored by: Jade9876554
Service checker says no problem but my internet light is out.
Re: No middle green light
@Jade9876554
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
