Discussion topic: WiFi not working
This message was authored by: Ant63
WiFi not working
My WiFi is not working as it should
Re: WiFi not working
@Ant63
You pisted at 0328. When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's still a problem after 7am and you haven’t done it yet, you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
