1
This discussion topic has been answered Discussion topic: WiFi keeps drpping
This message was authored by: Glynn08
WiFi keeps drpping
I work from home during the night and WiFi keeps dropping out I have up graded to gagafast so it's running at 910 atm why is it dropping out
Re: WiFi keeps drpping
@Glynn08
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's still down in the morning and you haven’t done it yet, you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@Glynn08
