Discussion topic: WiFi not working ??
This message was authored by: Shannnnn
WiFi not working ??
Is sky down ?
Re: WiFi not working ??
@Shannnnn
Not here. Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
