Discussion topic: WiFi is not working
This message was authored by: Darrencrick1974
WiFi is not working
The checks show everything is OK on the Sky app but we cannot connect to wifi
Re: WiFi is not working
@Darrencrick1974
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
