Discussion topic: Box is showing all ok but no connection
Message posted on 18 Oct 2025 12:24 PM
I have no Internet connection
My box has 4 green lights
WiFi on phone says connected with no Internet, no devices connecting
Message posted on 18 Oct 2025 12:34 PM
							Re: Box is showing all ok but no connection
@Suzbell81
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
If you’re still having problems you may need to contact Sky to report it.  The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
