Discussion topic: WiFi not working
Message posted on 11 Oct 2025 05:47 PM
WiFi not working
WiFi will connect to everything but does work , the light on box are green but still an issue with it . All the steps have taken to the box and still nothing . This has been for the last 24 hours so far
Message posted on 11 Oct 2025 07:35 PM
Re: WiFi not working
Not sure what you mean by this so apologies if you have already done this but have you tried rebooting the box at the mains ?
If that doesn't fix it try running this line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 11 Oct 2025 09:29 PM
Yes that has all been done
Message posted on 11 Oct 2025 10:16 PM
@ZOEY2085 When you called sky did they find anything from there testing?
