Discussion topic: Wifi Wifi
This message was authored by: KehindeAmosu
Wifi Wifi
Hello. My wifi is not working
Re: Wifi Wifi
@KehindeAmosu If the hub is not transmitting the wireless wi-fi signal so you can see it with devices, try reseting it by power off and back on after a few minutes! Failure to transmit the ssid name may be the hub or your device not seeing it!
