Discussion topic: WiFi not working
Message posted on 24 Sep 2025 10:57 AM
WiFi not working
WiFi won't work checked all connections and restarted but still nothing
Message posted on 24 Sep 2025 12:25 PM
Re: WiFi not working
@Ella1233
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
