Discussion topic: WiFi not working
Message posted on 28 Aug 2025 07:21 PM
WiFi not working
My wifi box all green but internet connection not working. I have reset box and tested connection. Not connecting to my television or phone. Entered password a few times. Disconnected it from my television but nothing. Turned it off by the. Switches and plugs. Turned it off by white box also
Message posted on 29 Aug 2025 07:21 AM
Re: WiFi not working
@TiaPhillips Very strange if tge hub has green lights it is connected to the exchange. Bring your phone close to the hub and check if it is connecting - the WiFi indicator on the screen is there. If the phone is connected but no data flows unplug your hub for an hour as there is a rare fault with Sky's server managing the line which causes these symptoms the hour disconnect should clear that.
If the fault continues call Sky.
