Discussion topic: WiFi not working
Message posted on 30 Jul 2025 05:49 PM
WiFi not working
My WiFi ain't working
Message posted on 30 Jul 2025 05:51 PM
Re: WiFi not working
@Selena
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
