Discussion topic: Speed to hub dropped!
This message was authored by: Tagen
When installed about 3 months ago speed was between 12 to 16 mb, now I only get between 2 & 3 mb.
Engineer fitted new connection box & reset system, but no better!! Help!!
Re: Speed to hub dropped!
@Tagen Are you on an old ADSL connection far away from the exchange!, also which sky hub are you using!
Avatar for Tagen
On ADSL useing Hub supplied by Sky.
But of a distance from cabinet, but do not understand how a few weeks ago I was getting Up to 16mb, now lucky to get 3mbps & engineer came this morning a found no faults!
@Tagen If you want to follow the link below, post up your stat's as you see them per the sample picture, just give it a time to fill in the data fields will take a look see!
How to read your Sky Hub statistics
