Discussion topic: WiFi not working
Message posted on 20 Jun 2025 01:01 PM
WiFi not working
WiFi not working, turned off and on again, orange lights on route for internet and voice
Message posted on 20 Jun 2025 01:04 PM
Re: WiFi not working
@Kate203
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
