Discussion topic: The rounter is not working
Message posted on 20 Jun 2025 12:43 PM
The lights on the rounter.
Message posted on 20 Jun 2025 12:55 PM
Re: The rounter is not working
@Kai8
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
