Discussion topic: WiFi not working
This message was authored by: Dearden9
WiFi not working
I just phoned snd your automated message agreed I have s problem with my home set up but service checker says everything is fine.  It's not since plugging it in 2 days ago it's worse than before and I am paying for a better service.  I think I want to cancel and go back if was better before. I have screenshots of not being able to access when if say no internet but the scale is showing everything is fine!
Re: WiFi not working
@Dearden9
The service checker looks for issues in your area so might not pick up something on your line only..
So try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Dearden9
Thank you but I've tried all this everything is fine except it's not
You will need to call again and when you do stay silent when asked anything by the bot and remain on the line as that should get you through to talk to someone.
