Discussion topic: WiFi not working
This message was authored by: Biffsh
WiFi not working
WiFi doesn't work.
checked all connections
Done restart test
Disconnected for 5 minutes
Re: WiFi not working
@Biffsh
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
