Discussion topic: WiFi not working
Message posted on 20 Feb 2025 02:13 PM
WiFi not working
the Wi-Fi keeps on dropping out. It happens all the time but says there is no issue in service checker. This is a nightmare as I work from home
Message posted on 20 Feb 2025 02:16 PM
Re: WiFi not working
@Linzi1328
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
