Discussion topic: WiFi issue
This message was authored by: Arf1
WiFi issue
Run a test on the sky website, and it says states that everything is fine. But I don't have any internet on any device
Re: WiFi issue
@Arf1
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
This message was authored by: GKS
Re: WiFi issue
Neither do I. It went the day before yesterday, came back last night, and now it's gone again.
Re: WiFi issue
@GKS
The same reply applies to you too.
This message was authored by: RMS2
Re: WiFi issue
I am having same issues. Checked all the links and no issues indentified. Have followed online instructions to restart and still nothing. It's dropped out a few times over the last week now and it's really frustrating. Is there anything else I can try?
Re: WiFi issue
Mine's working now. It looks like the outage from the other day switched off my OpenReach box. If you're on OpenReach, unplug the box, leave it for a few minutes, then plug it back in and press the on/off switch. That should reset everything and hopefully get your internet back like it did mine.
