Discussion topic: WiFi not working
This message was authored by: Ahucheke
Message posted on 23 Dec 2024 04:43 AM
WiFi not working
My WiFi is not working despite tests showing it's ok, it's not connecting from my devices and this seems to be a regular occurrence
Find out more
Message posted on 23 Dec 2024 07:31 AM
Re: WiFi not working
@Ahucheke what do the lights on your hub show? See https://www.sky.com/help/articles/hub-lights-explained-start
If your hub has lost connection to the line and the My Sky app's connection test doesnt tell you Sky are aware of a fault call them to report it.if the hub is connected the issue is in your home with the WiFi connection from the hub to the device.
