Discussion topic: WiFi not working properly when connected to mobile
Message posted on 05 Jul 2025 07:59 PM
My WiFi doesn't seem to be working properly when connected to my mobile. It works on every other device fine, I can stream on my TV with no issues, use my laptop and computer with no issued. But my mobile slowly gives up with the WiFi, I'll toggle it on and it will work fine for a few minutes and then I will have to toggle it off because it stops working. I have done all reset options for my mobile and WiFi.
My mobile used to show a message that said connected no Internet. Im not sure if this is an issue with sky or my mobile is losing the ability to connect to the WiFi
Message posted on 05 Jul 2025 08:08 PM
Re: WiFi not working properly when connected to mobile
@Eddie143 Since you have only one device issue see if the help below gets you where you need to be!
Connecting devices to your Sky Broadband | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 05 Jul 2025 08:17 PM
Hi, I can connect to the WiFi and it shows I'm connected but when I'm connected it takes a while to load or not at all.
Message posted on 05 Jul 2025 08:42 PM
@Eddie143 You could remove the wi-fi connection details completely from the mobile phone by telling it to forget the network details, if you do be sure to power off the phone before trying to re-connect it!
Message posted on 05 Jul 2025 10:43 PM
I've already tried this with forgetting the WiFi. I have also made sure the software on my mobile is up to date, I've soft reset my phone, reset my WiFi router, edited the IP and Mac settings on the WiFi mobile settings, reset my mobile multiple times, checked the connection to each device on the sky app and there's no issues with the connectivity. It only seems to be my mobile that is having issues. I can connect to everything else fine, I'm streaming netflix with no lags or buffers on my TV but I cant play a tiktok video on my mobile without it pausing every 2 seconds. It's only me and my partner and we have our own mobiles and usually watch TV together. Other than our wireless cameras and doorbell there isn't much else connected to the WiFi. We can both run our work computers fine at the same time as well but my mobile just isn't connecting like it used to.
I think we have full fibre 150 with a white hub .
My phone is a Samsung galaxy S21 ultra, its roughly 3 years old.
Message posted on 05 Jul 2025 10:54 PM
@Eddie143 the link i sent, did you look at it connecting older devices, turn down the max to wpa2-psk mode!
Message posted on 05 Jul 2025 11:25 PM
Hi, yes I have already changed the security level to WPA2 and it didn't improve anything
Message posted on 05 Jul 2025 11:27 PM
Hi, yes I have already changed the security level to wpa2 and it didn't improve anything
Message posted on 06 Jul 2025 07:02 AM - last edited: 06 Jul 2025 07:32 AM
@Eddie143 Problem i had with my Samsung A54 was symptom wise, no issue connecting, always fine download would drop from 500Mb/s all the way down to 12Mb/s, upload was always 100% at the 70Mb/s mark, fix was simple, wireless off, wait 5-10 seconds wireless on and back to full download speed instant on re-connect, it may stay that way for a few hours, think longest was about 8hrs, eventually it would just decay away, once it got down to low speed IT WOULD NEVER recover, had to wireless off/on.
I fought it hard for 2 months was not a priority as not a phone guy, for me phones are for making calls, nothing else....
To test it out and get to the bottom off it, i placed the phone next to my Asus router test took 48hrs so i was 100% sure, as i had come to the conclusion the ONLY think that this can be is POOR wireless signal strength, periodically checked it, fine running max speed, displaying synced at 1200Mb/s, so great no issues, nothing to do with the phone just likes to have a strong signal...
Order another AP for coverage, it arrived 30/6 and installed it imediately and not had one single issue since then.
Would have swore blind nothing to do with the hub, signal at phone hoovered around the -62db range, not great but not bad also now new AP -38db which is excellent at the best off times. Pictures on the link below if you need to see.
Message posted on 06 Jul 2025 07:12 AM
@Eddie143 Keep it simple therecshould be no need to edit mac or IP addresses instead simply set the mobile to get the settings from the hub automatically at most edit the DNS setting to add a public DNS address to the list I find Google's service works for me at 8.8.8.8 and 8.8.4.4. Otherwise use the vanilla settings shich should work. There is no pressing need to use some of the security services that ios and Android offer like private ip addrsssing etc on a trusted home connection so try turning these off. Also check is a setting on your mobile data called wifi assist or something similar isnt active as that can cause phones to jump between wifi and mobile if the phone things mobile data is better.
Message posted on 09 Dec 2025 03:42 PM
Hi JIM
I have the EXACT same issue. No help from SKY or acknowledgment. Kicks me off about 7-10 times per day. I turn the wifi off on the phone and back on again, which sometimes works but not always. I've had to buy a more expsenive data plan on the phone because sky just isnt working!! Any solution??
Message posted on 09 Dec 2025 03:59 PM
@GSE Sorry but you post just does not give any information that would help in the slightest, i have no issues at all now with the mobile phone, the AP fixed that! As for the data plan what has that got to do with a mobile connected on a wireless wifi network?
Message posted on 09 Dec 2025 04:05 PM
to explain in detail. My sky broadband works well. It does not work well on the phone. The phone kicks off the wifi about 7-10 times per day. It does not do this with the computer or any other device in the house. Ive tried iphone and android. Same issue. Ive tried some steps you have done but am unclear as to what solved it?
"Data " reffereing to the extra data I had to buy on mobile (yes mobile) because broadband wasnt working!
Message posted on 09 Dec 2025 04:16 PM
@GSE Two questions, what sky hub are you using, and then what mobile are you talking about, My system is Asus in AI mesh and a Samsung A54 mobile running android! An extra AP Asus RP-AX58 where the phone dropped the speed fixed the issue out, problem was when the phone tanked it just would not auto recover back up to speed, not that i cared to much about that, just got up my goat at times, no rush to fix it if there was would have been all over it like a rash!
