Discussion topic: WiFi not reaching bedroom
This message was authored by: Klcar
Message posted on 06 May 2026 10:17 PM
Hi so the WiFi's not always reaching my bedroom and when it does it keeps dropping and lagging I've done all the steps but has not worked
Find out more
Message posted on 06 May 2026 10:19 PM
Re: WiFi not reaching bedroom
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
