Discussion topic: WiFi not connecting
Message posted on 25 Jul 2025 03:23 PM
WiFi not connecting
I've checked and it says no problem but it won't connect the internet light isn't on on the router resetting hasn't helped
Message posted on 25 Jul 2025 03:44 PM
Re: WiFi not connecting
@Jenn63
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
