Discussion topic: WiFi not connected
Message posted on 05 Aug 2025 07:23 AM
WiFi not connected
I need my wifi to work all over my house as it has always done, but doesn't at the moment.
Message posted on 05 Aug 2025 07:48 AM
Re: WiFi not connected
@Liz68 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
